Hi all,
I started Solidworks. I created a new assembly. Then I opened Toolbox and I added a part from it:
JIS - Bolts and Screws - Hexagon Socket Head Screws - Hex Socket Head Cap JIS B 1176
I've set the parameters to M6 , Length = 20, Thread Type - simplified
The part was added to the assembly. I clicked on the part and I clicked edit, then I modified material, then I clicked Save As, and I saved the part with a the new name.
OK, now I got a named screw part, made from a specific material. So far so good.
Then I repeated the whole above process, except one step, I've set cosmetic and schematic thread type. (I always closed Solidworks between steps)
Now I have 3 files with different thread display types :
a simplified one 161 kByte
a cosmetic one 1476 kByte
a schematic one 365 kByte
And this is my question, this is what I don't understand. The cosmetic is significantly bigger than schematic. I assume that is bigger in the memory too. So whats the point ? Why would I choose cosmetic, at all ?
I can see one thing, the cosmetic has the schematic feature, the whole detaile thread, but its suppressed so its not visible. But it takes the files size.
I could be wrong but my video card is able to handle lot of vertices, that is not the bottleneck, but the memory footprint is much more important.
I want some clarification about these things, because its not clear. What makes Solidworks slower the cosmetic thread or the schematic one ? I understand the intention, but it does work indeed, is cosmetic faster , someone checked this ever ?
Because in my experience the supression doesn't make things faster.
I made the following experiment :
I've created a big assembly with lot of parts and lot of mates and relations between parts. It was bloody slow of course.
Then I've set every single part to "fixed" and I suppresse their mates, because it was not necessary anymore. There was no relation between the parts anymore , all parts were fixed ! And it was the same bloody slow !
I don't understand these things, I might be silly.
Regards,
Laci
PS: sorry for the long letter
