I'm looking to add a prefix, such as "1-", to all of a certain configuration specific properties named "ItemNumber".
However, I've not been able to find a method using Dispatch to add this prefix in the manner I want.
For example:
Part1
Old New
Config ItemNumber ItemNumber
00 123456 1-123456
01 123457 1-123457
02 123458 1-123458
Is this even possible with Dispatch without knowing the configuration names in advance?
Without having a fixed list of configuration names, you cannot achieve this. This is because when you update a variable with Dispatch, you have only two options for configurations: The first is blank, which will update all configurations, and the second is by specifying which configuration to update.
Regards
Martin
