I want to mirror green colour feature to opposite site about top plane. Different result is obtained when Geometry Pattern is check marked and not check marked.
Please explain the difference about two different results.
Here is my take on it Maha,,, Since that Boss-Extrude1 is up to surface, when you don't pick geometry pattern it still is looking for that same surface.. When you pick geometry pattern it is like what you see is what you get. It removes the up to surface from the mirror.
