Many years ago a collegue managed to add a general table into our sheet format. (for tolerance ect.) Now i would like to make an new update for all our templates. With a table for materials, quality, changes of the drawing ect. The collegue has left the company before i even joined. I cant manage to add a general table to the sheet format.
When you try to edit sheet format the table always disappears. But when you reload or make a new sheet it will load the table. How do i add a general table to my sheet format?
Regards,
Koen
I managed to get it done. The missing part was the connection with the "file location"
Save your drawing sheet and template sheet in the template map which is refered to "file location" --> "document templates"
Only the FIRST time you make a new drawing you have the option to select the drawing with a general table in it. After that you can only update the sheet template.
I hope this will help others aswell:)
