6 Replies Latest reply on Sep 21, 2017 9:42 AM by Josh Brady
    VBA - Macro wont process sketches of Holes
    Cad Admin
      Macro below processes a part and fully defines all sketches.
      The Issue is it wont find/process the sketches of holes. It processes all other features, but holes it skips.  The debug also shows all features except hole sketches.  I have use other macros from the API, to select the sketches manually and they show as expected, as "Feature Type: ProfileFeature".
      Open to all thoughts....
      Option Explicit
          Dim swModel                 As SldWorks.ModelDoc2
          Dim swFeature               As SldWorks.Feature
          Dim bValue                  As Boolean
          Dim swSketchManager         As SldWorks.SketchManager
          Dim swModelExtension        As SldWorks.ModelDocExtension
          Dim lStatus                 As Long
          Dim lMarkHorizontal         As Long
          Dim lMarkVertical           As Long
          Dim swSelectionManager      As SldWorks.SelectionMgr
          Set swModel = swApp.ActiveDoc
          Set swModelExtension = swModel.Extension
          Set swSketchManager = swModel.SketchManager
          Set swSelectionManager = swModel.SelectionManager
          swModel.ClearSelection2 True
          ' These are the marks expected for the dimension datums
          lMarkHorizontal = 2
          lMarkVertical = 4
          Set swFeature = swModel.FirstFeature
          Do While (Not (swFeature Is Nothing))
              Debug.Print "Feature Name: " & swFeature.Name
              Debug.Print "        Feature Type: " & swFeature.GetTypeName2
              If (swFeature.GetTypeName2 = "ProfileFeature") Then
                  If (Not (swFeature Is Nothing)) Then
                      bValue = swFeature.Select2(False, 0)
                      swSketchManager.InsertSketch False
                      bValue = swModelExtension.SelectByID2("Point1@Origin", "EXTSKETCHPOINT", 0, 0, 0, False, lMarkHorizontal Or lMarkVertical, Nothing, 0)
                      lStatus = swSketchManager.FullyDefineSketch(True, True, swSketchFullyDefineRelationType_e.swSketchFullyDefineRelationType_Vertical Or swSketchFullyDefineRelationType_e.swSketchFullyDefineRelationType_Horizontal, True, 1, Nothing, 1, Nothing, 1, 1)
                      swSketchManager.InsertSketch True
                  'Exit Do
              Set swFeature = swFeature.GetNextFeature
          Loop
        • Re: VBA - Macro wont process sketches of Holes
          Josh Brady
          I assume that you're talking about Hole Wizard feature holes?
          I haven't checked myself, but I believe the sketches for Hole Wizard holes are sub-features.
            John Alexander
            Just a suspicion: the problem has to do with hole wizard features containing two sketches. It looks like you are selecting each feature on the tree and then calling SketchManager.InsertSketch() to begin editing. I think this works most of the time because features tend to only have one sketch driving them. For hole wizard features, it is failing because it can't resolve which of the two sketches to begin editing.
            I think you'll have to change your approach to getting the sketch. Instead of selecting the feature and calling SketchManager.InsertSketch, maybe try selecting the sketch.
            Maybe something like this would work. It assumes that sketches are returned as child features. If so you'll also have to specify what gettypename2 returns for sketches.
            for each vChild in swFeature.getChildren
                 set swChildFeature = vChild
                 if swChildFeature.gettypename2 = "" then 'I'm not sure which sketch type will be returned, looks like there are several
                      bValue = swChildFeature.Select2(False, 0) 'select this feature
                      exit for
                 end if
            next vChild
            2012 SOLIDWORKS API Help - GetChildren Method (IFeature)
            2012 SOLIDWORKS API Help - GetSpecificFeature2 Method (IFeature)
            2012 SOLIDWORKS API Help - GetTypeName2 Method (IFeature)
                Josh Brady
                Children is actually the opposite of what you want.  The Hole Wizard feature is actually a child of its sketches.  GetParents would probably work.  But that would return any features that it's dependent on.  The SubFeature route is the way to go.
                    Cad Admin
                    So add a subfeature to process Hole Wizard feature holes only, and get the sketches for them there?
                        Josh Brady
                        Sort of this-ish.
                        Option Explicit
                            Dim swSubFeat               As SldWorks.Feature
                            Dim lStatus                 As Long
                            lMarkHorizontal = 2
                            lMarkVertical = 4
                                    'Exit Do
                                Set swSubFeat = swFeature.GetFirstSubFeature
                                While Not swSubFeat Is Nothing
                                    Debug.Print , "subFeature Name: " & swSubFeat.Name
                                    Debug.Print , "        subFeature Type: " & swSubFeat.GetTypeName2
                                    Set swSubFeat = swSubFeat.GetNextSubFeature
                                Wend
                            Loop
