Hey all,
I keep coming up to an issue where I am working top-down and would like to create subasemblies/subweldments from my top level assembly. Is there a way to use the "form new subassembly" and not lose all the mates I have established? For example, in the photo, the box and the two mounting plates are a part of one weldment, while the tube and the other set of plates are a part of another. I would like to define the location of the mounting plates via the geometry on the second weldment. From what I know, the only way to keep this parametric relationship is to bring the second weldment into the first one and hide/exclude from BOM after mating (so essentially the second weldment is in the top level assembly twice).
I have also been playing around with the first assembly being "flexible." This allows me to make the mates that I need, but they don't trickle down to the lower levels.
Thanks in advance!
Jeremy K., CMfgT
Jeremy Kepley - If you're wanting to do Top Down design then your Design Intent should have a common part that you can build off of and the sub-assemblies need to be made as you go. The common part that I talking about is either a Skeleton Sketch Part or a Master Modeled Part or a combination of the two. There is quite a bit on Top Down Design here on the forum and a lot of guys ready to assist you. For a crash course see the attached PDF
