I wanting to know how I could get this blocked to form to the tire. Will be using a block of rubber and would like some help thanks. Here are the components thanks.
I have changed the tire dimension anyway someone could make a quick example drawing showing the rubber layout on the tire on the 30 degree angle like that?
Jacob,.. there are a few ways to do this but for your current layout using the assembly,.. I'd suggest copying the surface of the tire into the rubber and doing a Wrap scribe of your sketch at the angle you need.. then, pattern at the assembly if you need it to be independent?
I would start by dimensioning circle.
