Have a look at the Weldment Cut List below and notice the lack of consistency in how the lengths are displayed - some have no decimal places; others have two or three. How can I make all of the lengths display at two decimal place accuracy?
Hi Bill,
Go to the weldment part and check the linked dimensions. The drawing document unit settings will be superseded it you assign a custom format to the driving dimension in the weldment part. I.E. got to the model dimension and assign a custom precision, other than document setting. That's what I would check if the dimension doesn't happen to be true integer.
Elmar
If the length values come from dimensions in the model then change those to two places. Or you may need to change the document properties in the model to two places plus change settings so trailing zeros are shown.
