Why use this code to set text content of balloon incorrecttly ?
Question asked by Li Feng on Sep 18, 2017
Latest reply on Sep 18, 2017 by Li Feng
Hi All,
when I use these code the set the text content of the balloons to be the component name where it attached, it could not set the component name one to one, but set all the text of balloons to be 1 same component.
Any guys can point out what 's wrong about it ?
pls check my code and video to know the detal.
thanks a lot
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swSelObj                As Object
    Dim swAnn                   As SldWorks.Annotation
    Dim vAttEntTypeArr          As Variant
    Dim vAttEntArr              As Variant
    Dim i                       As Long
    Dim swEnt As SldWorks.Entity
    Dim bRet As Boolean
    Set swModel = swApp.ActiveDoc
    Debug.Print swSelMgr.GetSelectedObjectCount
    Dim j As Integer
    For j = 1 To swSelMgr.GetSelectedObjectCount
        If swSelMgr.GetSelectedObjectType3(j, -1) = swSelNOTES Then
            Set swSelObj = swSelMgr.GetSelectedObject6(j, -1)
            Set swAnn = swSelObj.GetAnnotation
            Debug.Print "AnnName              = " & swAnn.GetName
            vAttEntArr = swAnn.GetAttachedEntities3
            Dim CompName As String
            Dim SetAnnName As Boolean
            Dim swModelDocExt As SldWorks.ModelDocExtension
            Dim swNote As SldWorks.Note
            Set swEnt = vAttEntArr(0)
            Set swComp = swEnt.GetComponent
            CompName = swComp.Name2
            Set swModelDocExt = swModel.Extension
            Set swNote = swSelObj
          'why this code set all the balloons to be 1 same Component name ?
            Set swNote = swModelDocExt.EditBalloonProperties2(swBalloonStyle_e.swBS_Circular, swBF_3Chars, swBalloonTextContent_e.swBalloonTextCustom, CompName, swBalloonTextCustom, " ", 0, True, 1, "X", 0.001)
    Next j
Regards
Vincent
