Please tell me how to get the palette to show up. Please don't respond with the space bar answer regarding the "easy mode". Really sick of this happening. If I have to delete the preferences again, not going to be happy.
Hi Michael,
Can you please describe what you are doing or what is happening that makes the Palette disappear? Are you using dual monitors perhaps?
Thank you,
Brian
It would be great to know what triggers it. Do you ordinarily run with the palette detached from the main application window? May have to run like that for a while myself to see if the issue gets triggered...
Meanwhile, exit Visualize, then delete just this one file (this will only reset your window layout, not any of your other settings)
%localappdata%\SOLIDWORKS\SOLIDWORKS Visualize 2017\InterfaceLayout.xml
Restart and windows should be back to out of box state, with palette docked and visible on the right.
Not much expertise with Visualize but can you get it under View menu
