I'm using FullyDefineSketch to dimension a hole wizard sketch. I would like to dimension this pattern with respect to the part's origin.
The function takes two arguments for the datum:
VerticalDatumDisp
HorizontalDatumDisp
If either of them are Nothing, the FullyDefineSketch method uses an entity with selection mark = 6. Otherwise, one should pass the desired Entity object for those parameters.
I've tried the selection approach using the following function:
Sub selectOrigin(swModel As SldWorks.ModelDoc2)
Dim swFeature As SldWorks.Feature
Dim bRet As Boolean
Set swFeature = swModel.FirstFeature
Do While Not swFeature Is Nothing
If swFeature.GetTypeName = "OriginProfileFeature" Then
bRet = swFeature.Select2(True, 6): Debug.Assert bRet
Exit Do
Set swFeature = swFeature.GetNextFeature
Loop
This doesn't have any impact on the FullyDefineSketch's output.
I would like to get a reference to the origin and pass it to this function. However, I have no idea what type of object the origin is. I know when a sketch is active, a projection of the origin is visible on the sketch in the graphics window. Although, I don't think that the origin shows up as a sketch entity and I don't know how to get a reference to it programmatically.
Public Function getOrigin(swModel As SldWorks.ModelDoc2) As SldWorks.Feature
Dim bRet As Boolean
Set getOrigin = swFeature
Exit Function
Loop
End Function
I've tried passing the OriginProfileFeature to FullyDefineSketch with no positive result and I've tried casting the OriginProfileFeature as an Entity and passing that as an argument. That didn't work either.
When I select the origin via the feature tree with the FullyDefineSketch tool open, it calls it "Point1@Origin" (Is "Point1@Origin" a Vertex? a Reference Point?)
Whereas, when I get the name of the feature via the API, it is just "Origin"
Set swOriginFeature = getOrigin(pModel)
Debug.Print (swOriginFeature.Name)
Does anyone have experience with using the Origin in the API?
John Alexander
its actually a sketch point.
Point1@Origin is the sketch point name.
Origin is the Sketch Feature Name.
copy this method
Public Function GetOriginSketchPoint(ByVal SwModel As SldWorks.ModelDoc2) As SketchPoint
Dim OriginFeat As Feature
Set OriginFeat = getOrigin(SwModel)
Dim OriginSk As Sketch
Set OriginSk = OriginFeat.GetSpecificFeature2
Dim SkPt As SketchPoint
Set SkPt = OriginSk.GetSketchPoints2(0)
Set GetOriginSketchPoint = SkPt
End Function
enjoy
