Run a macro during a PDM Task
Question asked by Raul Borobio on Sep 15, 2017
Latest reply on Feb 13, 2018 by Ales Svoboda
Hello
I'm not so experienced with the SW / EPDM Api. I need to run a simple piece of code during a EPDM task.
We need to generate a dxf and a pdf from a .dft file (Solid Edge).
I've tried to replace the convert() function by my code with no success.
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Dim objSheet As SolidEdgeDraft.Sheet
Dim FilePath_VA As String
    Set objApp = CreateObject("SolidEdge.Application")
    objApp.DisplayAlerts = False
            FilePath_VA = "C:\Users\raul.SERVER\Desktop\ES_007162.dft"
            Set objDoc = objApp.Documents.Open(FilePath_VA)
            objApp.Visible = True
            objDoc.SaveAs ("C:\Users\raul.SERVER\Desktop\ES_007162.pdf")
            Call objDoc.Close
Call objApp.Quit
Set objApp = Nothing
Set objDoc = Nothing
Set objSheet = Nothing
I understand that the task add-in needs to open and save files from a solidworks file. Then, I was asking myself if is it possible to trigger a 'dummy' solidworks file that trigger my Solid Edge macro. If yes, what about the generated files, will them be added to vault and checked in?
Sombebody has coded something similar?
Thank you in advance.
Raúl
