1 Reply Latest reply on Sep 15, 2017 9:38 AM by Matthew Cempa
    How can I export datum points referenced from a custom coordinate system into excel?
    Zach L.
      How can I export datum points referenced from a custom coordinate system into excel? I have found macros for sketch points but nothing for points referenced from a custom coordinate system, or even anything using datum points. Please help. I am dumbfounded.
        • Re: How can I export datum points referenced from a custom coordinate system into excel?
          Matthew Cempa
          you need transform the point from global to local coordinates.  There are many transforms happening in SolidWorks.  If you are working in a part it's pretty straight forward as below.  If you are in an assembly looking at a point in a component there is a transform for the component that comes into play.  On top of that in a drawing there is a view transform that needs to be accounted for.  I'll leave the excel work out of this post.  I have a complete macro to do this but unfortunately I can not share the entire macro here but I can share the basic technique required.  Hope this helps.  I pulled out some my code but this is not tested as is but works in my final code.
          Dim swFeat As SldWorks.Feature
          Dim swCsys As SldWorks.CoordinateSystemFeatureData
          Dim swTransform As SldWorks.MathTransform
          Dim swPt As SldWorks.MathPoint
          Dim swLocalPt As SldWorks.MathPoint
          Set swModel = swApp.ActiveDoc
          Set swMath = swApp.GetMathUtility
          Set swFeat = swSelMgr.GetSelectedObject6(1, 0) 'assumes the Csys is the first item selected.
          Set swCsys = swFeat.GetDefinition
          Set swTransform = swCsys.Transform
          ' Code to get the point to work with goes here
          Set swLocalPt = swAssyPt.MultiplyTransform(swTransform.Inverse)
