How can I retrieve the mass of a single component in the custom properties of my assembly....but after it has been assembly cut?
Question asked by Dan Pihlaja on Sep 14, 2017
Latest reply on Aug 2, 2019 by Dan Pihlaja
Basically, what I want is the syntax that is needed in the assembly custom properties to pull the mass of a single component, but after it has been assembly cut
(which means that I don't want to pull the mass from the part document...I want the current mass as it is in the assembly, and I need to use that in my custom properties of the assembly).
It should be something like "SW-Mass@component name@assembly config@assembly filename"  But I can't get that to work.
Does this make sense?
