Steve Holland
Top 20 Most Accessed KB Solutions in August 2017
Discussion created by Steve Holland Employee on Sep 13, 2017
    Hi Everyone. Here is the list of most accessed KB solutions for August. To view a KB solution, click on the associated link.
RankSolution IdQuestion
1S-073387Why does the SOLIDWORKS® 2017 SP4 software stop responding when I close files?
2S-072800When using NVIDIA® GeForce® graphics cards with the SOLIDWORKS® software, what can cause extremely slow performance?
3S-072608What can cause the SOLIDWORKS® 2017 software to take a long time to start as compared to the SOLIDWORKS 2016 version?
4S-073322After installing Microsoft® .NET Framework 4.7 on Windows® 7 or upgrading to Windows 10 Creators edition, how do I resolve instability with .NET Framework functionality within the SOLIDWORKS® software?
5S-048683Why does the SOLIDWORKS® Resource Monitor display "system resources are running low" on 64-bit Windows 7 machines?
6S-073155General Hotfix for SOLIDWORKS® 2017 SP3 (SPR#1024009)
7S-048684Why does a "system resources are running low" warning dispaly on Windows Vista® and Windows® 7 64-bit if not all of the Physical and Virtual Memory is used?
8S-069274Is there a tool for SOLIDWORKS® Enterprise PDM that can help verify connectivity between a client and server or between replicated servers to ensure the server and service ports are accessible?
9S-017133How can a user troubleshoot SOLIDWORKS® Enterprise PDM API add-in DLLs that fails to distribute or fails to load with error 'Failed to register the COM DLL' on client systems?
10S-061562How do I repair or uninstall and reinstall Microsoft® .NET Framework components?
11S-017826How can you restore a copy of a SOLIDWORKS® PDM file vault to a separate system from a SQL database backup (.bak) in order to test upgrades or troubleshoot vault specific problems?
12S-03344How do I diagnose and resolve the following error that displays when I startup or run SOLIDWORKS in a network license environment, 'Could not obtain a license for SOLIDWORKS Standard. Server node is down or not responding. (-96,491,0)'?
13S-014069What does Windows® Installer error 1603 during an installation mean?
14S-051631How can a clean uninstall and reinstall of SolidWorks be performed?  Is there a cleanup utility that can be used to do this?
15S-020198What does the message "No database connected to this view" mean when browsing into a SOLIDWORKS® Enterprise PDM file vault view?
16S-069491When launching SOLIDWORKS® or opening a file, why does SOLIDWORKS return "Could not load SOLIDWORKS DLL: GdtAnalysisSupport.dll"?
17S-032108What could be a reason for the error 'Windows Sockets error '#10054: Connection reset by peer.' seen in a SOLIDWORKS® Enterprise PDM log file?
18S-012984How is a local SOLIDWORKS® Enterprise PDM file vault view manually removed / deleted?
19S-018842[...]\cosworks.dll cannot be loaded. Either the Add-in or one of its components is missing. (Version 2011 and up)
20S-034751What could cause the error 'Archive server could not open windows registry' when creating a local view or attaching to an archive server from a SOLIDWORKS® Enterprise PDM client?
