Collect HoleWizardFeature(s) on a Face
Question asked by John Alexander on Sep 14, 2017
Latest reply on Sep 14, 2017 by John Alexander
I'm trying to build a list of all HoleWizardFeature(s) on a face in the context of an assembly. This needs to include features that start on the face as well as any thru holes that break through the face. The purpose is to build a selection list for another macro that copies holes from one component to another.
The following function getHolesInFace takes a Face2 and should return an array of Features of type HoleWzd that intersect that face. It fails to get all intersecting holes.
Private Function getHolesInFace(swParentFace As SldWorks.Face2) As Variant
    Dim swFeature   As SldWorks.Feature
    Dim swEdge      As SldWorks.Edge
    Dim swFace      As SldWorks.Face2
    Dim vFaces      As Variant
    Dim vEdge       As Variant
    Dim swHoleWizardFeatures() As SldWorks.Feature
    Dim found   As Boolean
    Dim i       As Integer
    ReDim swHoleWizardFeatures(0)
    Set swHoleWizardFeatures(0) = Nothing
    For Each vEdge In swParentFace.GetEdges
        Set swEdge = vEdge
        vFaces = swEdge.GetTwoAdjacentFaces2
        'check the first face from getTwoAdjacentFaces
        Set swFeature = Nothing
        If Not vFaces(0) Is Nothing Then
            Set swFace = vFaces(0)
            Set swFeature = swFace.GetFeature
            Debug.Print swFeature.GetTypeName2
            Debug.Print swFeature.Name
            If Not swFeature.GetTypeName2 = "HoleWzd" Then
                'set Feature to Nothing if it isn't a HoleWizardFeature
        'check the second face from getTwoAdjacentFaces
        If swFeature Is Nothing Then
            If Not vFaces(1) Is Nothing Then
        If Not swFeature Is Nothing Then
           'insert the feature into the array if it is unique
            found = False
            For i = 0 To UBound(swHoleWizardFeatures)
                If Not swHoleWizardFeatures(i) Is Nothing Then
                    If swHoleWizardFeatures(i).Name = swFeature.Name Then
                        found = True
                        Exit For
            Next i
            If Not found Then
                If Not swHoleWizardFeatures(0) Is Nothing Then
                    ReDim Preserve swHoleWizardFeatures(UBound(swHoleWizardFeatures) + 1)
                Set swHoleWizardFeatures(UBound(swHoleWizardFeatures)) = swFeature
    Next vEdge
    Debug.Print "hole Count:"; (UBound(swHoleWizardFeatures) + 1)
    getHolesInFace = swHoleWizardFeatures
End Function
The Face2 that I pass as an argument is selected in the image below. You can see that the 11.0 dia holes and the 8H7 holes(green) interesect said Face.
Immediate Window:
ICE
Boss-Extrude5
ICE
Boss-Extrude5
ICE
Cut-Extrude1
ICE
Cut-Extrude1
ICE
Cut-Extrude1
ICE
Cut-Extrude1
ICE
Cut-Extrude1
ICE
Cut-Extrude1
HoleWzd
Ø11.0 (11) Diameter Hole1
HoleWzd
HoleWzd
HoleWzd
ICE
Cut-Extrude1
ICE
Cut-Extrude1
ICE
Cut-Extrude1
ICE
Cut-Extrude1
hole Count: 1
It seems to be finding edges associated with the "11.0 Dia" clearance holes but not the 8H7 reamed holes. Both of these are hole wizard features that appear to intersect the face in question.
I believe I've narrowed the problem down to Face2::GetEdges. It is not returning the edges at the intersection of the 8H7 hole features and the face (selected below).
Looking further, it appears that the CutExtrude feature that generated the Face was created after the 8H7 holes. The 11.0 Dia holes were created after the CutExtrude. I can imagine why that would make a difference but don't know how to use that information to proceed. My function needs to return the H7 hole regardless of its order in the feature tree. There should be a way of accessing those edges.
Does anyone have experience with this? Any suggestions are appreciated.
John Alexander
