Hi all,
I have a doubt regarding "apply scene".
With some curiosity, I have changed the scene in the top level assembly, due to reason the entire assembly changed to single color, but at the part level the applied color still exists(does not reflecting the same in the assembly level). Please provide with some solution.
Naga Ranjithkumar A
Color is for appearance, If you had applied it in top level assembly, delete the appearances under assembly. this will restore the one saved in parts in top level assembly. Make sure that you had set sort order to hierarchy instead of history. I hope this helps
Regards,
Daljeet Singh
