RGRyan Gaudreau11/09/2017
I've been working on a macro to automate drawings from an assembly.  The overall goal is for the macro to store the filepaths and names of all components in the assembly, and then start a new drawing, creating and populating the sheets with components in the three standard views.  I have it working where it will store all the filepaths and names, open a new drawing, and drop components into the first two sheets (the first two sheets are in the template), but fails at creating any new sheets.  I'm not too familiar with the drawing commands, and things seem to work differently for me than what is described in the API help. For example, "create3rdangleviews" command won't work with my drawingdoc instance but will with my modeldoc instance.  If anyone can help me with this it would be greatly appreciated.  I have my code posted below.  I really just need help with the new sheet creation and view insertion, I think once I get that working I will be able to figure out my other problems and goals that I have listed in the notes.  Sorry in advance for my code, it is probably sloppy and inefficient.
Dim swCompModel As SldWorks.ModelDoc2
Dim swDoc As SldWorks.ModelDoc2
Dim swSheet As SldWorks.sheet
Dim boolstatus As Boolean
Dim bRet As Boolean
Dim i As Integer
Dim h As Integer
Dim j As Integer
Dim k As Integer
Dim mypaths(50) As String
Dim mynames(50) As String
Dim mysheet As String
Dim myprops As Object
Dim vComps As Variant
    Set swModel = swApp.ActiveDoc
    Set swAssy = swModel
    h = 0
    vComps = swAssy.GetComponents(False)
    If IsEmpty(vComps) Then Exit Sub
    'TRAVERSES ASSEMBLY FOR PARTS/SUB ASSEMBLIES
    For i = 0 To UBound(vComps)
        Set swComp = vComps(i)
        Set swCompModel = swComp.GetModelDoc2
            'gets the full pathway for every component in an assembly (not the assembly itself)
            Dim vConfigNames As String
               vConfigNames = swComp.GetPathName
            'returns last 3 places in component title (ex 001, 200, ect) --- will be used to name sheets in drawing
            Dim vTitleNames As String
                vTitleNames = swCompModel.GetTitle
                    vTitleNames = Strings.Right(vTitleNames, 3)
            'this stores new names only and skips over duplicate parts
                For j = 0 To UBound(mypaths)
                If vConfigNames = mypaths(j) Then
                GoTo Skip
                Exit For
                Next j
            'STORES NEW PARTS, DUPLICATE PARTS SKIP OVER THIS SECTION FROM CODE ABOVE
            mypaths(h) = vConfigNames
            mynames(h) = vTitleNames
            'MsgBox (mypaths(h))
            'MsgBox (mynames(h))
            h = h + 1
Skip:
    Next i
    'closes assembly document
        'boolstatus = swApp.CloseAllDocuments(False)
'CREATE NEW DRAWING DOCUMENT
    Set swDoc = swApp.NewDocument("C:\SOLIDWORKS Data\PSF-GN.DRWDOT", 1, 0.2794, 0.2159)
    Set swDoc = swApp.ActiveDoc
    'INSERT CURRENT OPEN ASSEMBLY
    'FIRST PAGE NAME IN TEMPLATE = "GN" SECOND PAGE NAME = "2"
    'INSERTS VIEW INTO FIRST TWO PAGES, THIS WILL BE LARGE ASSEMBLY
    boolstatus = swDoc.Create3rdAngleViews(mypaths(1))
    'ACTIVATE SHEET "2", INSERT MODEL VIEWS
    boolstatus = swDoc.ActivateSheet("2")
    'GET TEMPLATE OF SHEET "2" TO BE USED IN NEWLY CREATED SHEET
    'mysheet = swSheet.GetTemplateName()
    'CREATE NEW Sheet, INSERT MODELS FROM MYPATHS(I)
        'trying to go through list of components, create a new sheet for each, and insert model views
        'For k = 0 To UBound(mynames)
-----fails here
            boolstatus = swDraw.NewSheet4(mynames(k), "", 12, "", "", "", "c:\programdata\solidworks\solidworks 2016\lang\english\sheetformat\a0 - landscape.slddrt", "", "", "", "", "", "", "", "", "")
            'boolstatus = swDoc.ActivateSheet(mynames(k))
            'boolstatus = swDoc.Create3rdAngleViews(mypaths(k))
            'Next k
    'SORT SHEETS BASED ON NUMBERS, THIS WILL PUT ASSEMBLIES FIRST --> METAL PARTS --> WOOD PARTS ECT
    'POSSIBLY ADD A CHOICE FUNCTION, ENTER YES IF YOU WANT TO FIT ANOTHER MODEL ONTO SHEET
        ' ENTER NO IF YOU WANT TO CREATE NEW SHEET AND INSERT MODEL
            ' THIS WOULD ALLOW PAGE BY PAGE CONTROL ON THE DRAWING, WOULD NEED TO SET UP ZONES
