3 Replies Latest reply on Sep 28, 2017 1:45 PM by Jacob Corder
    questions about getsketchregions and outloop
    Moon Wang
      hello,
      I get the sketch by 3DIntersections.when I used  getsketchregions ,it shows that the SketchRegionCount is 2,I doubt how it allocate regions(I thought the regioncount is 1),however when I get the firstloop and get the loop‘s edgecout ,the edgecount is 1,and OuterLoop isTRUE.So,the squence of loop is also a puzzle to me .who can help me,thank you
      my code is as below.
      swSketch = (ISketch)swFeature.GetSpecificFeature2();
      if ((swSketch != null))
                              regionCount = swSketch.GetSketchRegionCount();
                              vSkRegions = (object[])swSketch.GetSketchRegions();
                              for (i = vSkRegions.GetLowerBound(0); i <= vSkRegions.GetUpperBound(0); i++)
                                  skRegion = (SketchRegion)vSkRegions[i];
                                  if ((skRegion != null))
                                      j = 0;
                                      myLoop = skRegion.GetFirstLoop();
                                      while ((myLoop != null))
                                          edgeCount = myLoop.GetEdgeCount();
                                          vertexCount = myLoop.GetVertexCount();
                                          outer = myLoop.IsOuter();
                                          if (outer == false)
                                              strOuter = "Inner loop";
                                          else
                                              strOuter = "Outer loop";
                                          vEdges = (object[])myLoop.GetEdges();
                                          for (k = vEdges.GetLowerBound(0); k <= vEdges.GetUpperBound(0); k++)
                                              myEdge = (Edge)vEdges[k];
                                              if ((myEdge != null))
                                                  test1 = (Vertex)myEdge.GetStartVertex();
                                                  test2 = (Vertex)myEdge.GetEndVertex();
                                                  //vPoint = (double[])test1.GetPoint();
                                          vVertices = (object[])myLoop.GetVertices();
                                          for (k = vVertices.GetLowerBound(0); k <= vVertices.GetUpperBound(0); k++)
                                              myVertex = (Vertex)vVertices[k];
                                              if ((myVertex != null))
                                                  vPoint = myVertex.GetPoint();
                                                  X = vPoint[0];
                                                  Y = vPoint[1];
                                                  Z = vPoint[2];
                                          myLoop = (Loop2)myLoop.GetNext();
                                          j = j + 1;
        • Re: questions about getsketchregions and outloop
          Manikandan Babu
          Hi Wang,
          Lets try this code to get the edges.
          I hope its helps you
          class Program
                  static void Main(string[] args)
                     SldWorks Swapp=(SldWorks)System.Runtime.InteropServices.Marshal.GetActiveObject("SldWorks.Application.25");
                      ModelDoc2 SwModel = Swapp.ActiveDoc;
                      PartDoc SwPart = (PartDoc)SwModel;
                      Feature SwFeat = SwPart.FeatureByName("Sketch1");
                      Sketch SwSketch = SwFeat.GetSpecificFeature2();
                      Debug.Print(SwSketch.GetSketchContourCount().ToString());
                      object[] vSkContours = (object[]) SwSketch.GetSketchContours();
                      foreach (SketchContour SwSketcontour in vSkContours)
                          object[] VEdges = (object[])SwSketcontour.GetEdges();
                          Debug.Print(SwSketcontour.GetEdgesCount().ToString());
                          foreach (Edge SwEdge in VEdges)
                              Entity SwEnt = (Entity)SwEdge;
          Manikandan
