I’m assuming the browser loads all the images in the background to try to make moving around the model as smooth as possible. If this is correct, is there a recommendation as to how many orbits, and images per orbit, to get good performance in the browser and also smooth movement around the model?
My initial testing is all from local folders on the same machine running the browser, so that’s not a good indication to what performance over the internet will be like.
Hi Mark - welcome to the Visualize Community!
I typically use these settings for VR (Interactive Image) render. I've found they strike a good balance between interactivity with the model and render time.
Orbits = 5
Images per Orbit = 16
Start Angle = 0
End Angle = 70
5x16 = 80, so these render settings will produce 80 images stitched together. If this takes too long on your machine, decrease the Orbits to 4 and Images per Orbit to 12 - resulting in 48 images.
Happy rendering!
Brian
