Here's my problem:
I set up a custom property tab through the "Property Tab Builder" that takes input from designers, basically filling out a gear data table. I also had a sketch block that was basically just a spline profile so that designers could insert the block and then edit it to put their own values in and then use an extrude cut or swept cut to make the teeth.
What I want to know is: Is there a way to make sketch blocks pull the properties from whichever configuration the part was in when the block was inserted?
I have been playing around with it and can set up equations to pull from A SPECIFIC configuration but not variable configurations.
I hope that question was clear, any help on this would be appreciated.
Thank you.
