good afternoon,
I have created a part with the routing library manager and its located in the database also, even though, the part doesn't show any configurations and it says it's not a routing part. The design table is approved according to the routing library manager. When i drag and drop my own routing part, it asks for a configuration, but later in the menu left on the screen (where you can choose elbows also), the pipe doesn't show any configurations. see the screenshot for more clarification.
thanks in advance,
Rens
Rene,
The diameters at Cpoint1 and Cpoint 2 can't be all the same for all the configs because those values help dictate what size fiting it has to connect to. In other words, I don't think you want to connect an Elbow of 142 to a DM400
Fix those two columns and see if that helps.
By the way :
The columns $prp@pipeidentifier and $prp@specification can be empty but I strongly suggest that you learn what they are all about because they can make your life a whole deal easier when used properly.
Greetings from Belgium,
Peter
