Re: HOW TO DO FEA ON THREADS?
Christian Chu Sep 7, 2017 10:58 AM (in response to Evan Leftwick)I'm not sure if this can be done by the expression version. If yes, I really want to know too
Dan Pihlaja Sep 7, 2017 11:03 AM (in response to Evan Leftwick)I am NOT an FEA person....however, I would think that you need to first make sure that the threads that you modeled are exactly what will be produced by the method of manufacturing them (thread forming / thread milling / tap, etc...).
This is VERY rarely the case. Which is why most people don't put threads in their models anyway....just graphical representations.
Christian Chu Sep 7, 2017 11:20 AM (in response to Dan Pihlaja)first make sure that the threads that you modeled are exactly what will be produced by the method of manufacturing them (thread forming / thread milling / tap, etc...).
It's not about how to model the thread correctly, it's about how the thread can stand for certain stress
I really want to perform FEA on thread using the expression version including in the SW premium, but can't figure out a way to, unless I get a full FEA package.
Just used my common sense such as coarse for aluminum or fine thread for steel and more number of engaged threads for more strength ... It's a shame but I have no tool for it ...
Evan Leftwick Sep 7, 2017 11:07 AM (in response to Evan Leftwick)Dan,
If I can figure out how to get it to work I was going to do a stress test at LMC so I can see the worst case scenario.
Dan Pihlaja Sep 7, 2017 11:32 AM (in response to Evan Leftwick)Evan Leftwick wrote:
Dan,
You can do that I suppose. That would get you a number, however, in addition to LMC tap drill size, thread strength has a heck of a lot to do with the shape and the form of the thread as well as how much actual contact surface there is between the male and female threads.
That is what I meant by making sure that the model is the same as how it will be manufactured. Different manufacturing methods produce slightly different forms of threads.
If this were a safety item (like the thread needed to hold and I-BEAM over a crowd of people) then I would (in addition to the FEA), make sure that a heck of a lot of real world tests were performed.
Evan Leftwick Sep 7, 2017 11:44 AM (in response to Evan Leftwick)Dan,
I am a machinist, I am aware of the thread form and I will be making the parts myself. I will be testing the actual parts but I would like to catch anything ahead of time if possible so we don't waste a bunch of machine time. I guess nothing is as good as real world testing.
Dan Pihlaja Sep 7, 2017 11:51 AM (in response to Evan Leftwick)Evan Leftwick wrote:
Dan,
Awesome. I didn't mean any offense.....I just wanted to make sure that all was covered.
Now, on to your question......I have no idea. LOL Never actually run an FEA in Solidworks.
Evan Leftwick Sep 7, 2017 12:01 PM (in response to Evan Leftwick)No offense taken Dan, thanks for the thoughts.
Bill McEachern Sep 7, 2017 1:11 PM (in response to Evan Leftwick)Most people, including me, usually use a revolve feature for the thread, the helix angle is often very slight and it is best ignored as it complicates the analysis to impracticality in many cases. The initial tightening can be modeled by applying a tensile pre load to the bolt. Threads in tension have a stress riser of between 3 & 7. You can search for a GMRI presentation of the analysis of bolts in tension. If might be useful to start with that.
Roland Schwarz Sep 7, 2017 2:10 PM (in response to Evan Leftwick)The problem with threads is that they are relatively tiny features on much bulkier parts. You would need extremely fine resolution at thread roots. Perhaps possible with auto mesh refinement.
None of this would account for the microstructure changes that affect thread strength. You may get a solution to converge, but it's not likely to be accurate.
Christian Chu Sep 7, 2017 2:25 PM (in response to Roland Schwarz)it's what I thought ...
assume the full FEA package would be used to perform the analysis ...
Bill McEachern Sep 7, 2017 2:28 PM (in response to Roland Schwarz)With all due respect to Roland Schwarz, I believe you can get an accurate stress solution to a thread that lines up with experimental data. I know others that through considerable resources at such problems but it is pretty much restricted to just modeling the fastener system. You do need a boat load of elements typically. Roland what do you mean by changes in micro structure? At least as far as I know, typically the micro structure of a metal does not change with stress state even post yield. It would have to go from say BCC to FCC and typically that is a temperature dependent thing, no?
Roland Schwarz Sep 7, 2017 2:38 PM (in response to Bill McEachern)Good points, Bill. True, the stress solution may be accurate. However, there will be changes to other properties, most notably hardness and strength. Localized working can embrittle the material. At that scale, imperfections due to cutting or rolling will have a significant effect. Even if parts are molded, there will be significant variations in material properties due to skinning and differences in cooling rates.
Bill McEachern Sep 7, 2017 2:50 PM (in response to Roland Schwarz)Hi Roland, the material property changes (strength and stiffness) are typically accounted for in the plasticity model selected, along with the hardening if multiple load applications are specified. Imperfections while hard to model, upon yielding would tend to smooth out with a sufficiently fine mesh. This is where some experimental work can establish the impacts of imperfections so that modeling can account for them in an average sense. On the cooling effects, they can be accounted for if known by having different material properties for different zones. Most advanced programs can even model fracture and crack propagation (though not SWX Sim as yu would know). This discussion is probably beyond what was intended by the OP. Maybe its helpful in highlighting how complicated things can get and what can be done if you dig in enough.
Ananda Ganesh Madheswaran Sep 25, 2017 3:24 AM (in response to Evan Leftwick)hi...
if you want to see the failure / strength of the thread, you have to model thread in the part and apply contact to the thread and also to the mating hole..model the thread by sweep option with helix and the mating area by just making the cavity on it.
provide the contacts between them and apply the required force / load.
Elmar Klammer Sep 25, 2017 7:15 AM (in response to Evan Leftwick)Hi Evan,
Rather than solving your joint in 3D us 2D analysis. That solve much faster and can provide just as good results.
The kind of loading on the bolt is important just like the joint overall design plays an integral part in the load behavior of your joint.
If I was to do a 3D analysis then I would consider to combine standard mechanical thread theory and 3D simulation tools.
That way I can simplify my analysis and make some assumption on the joint stiffness etc. since flexible joints cause bending in the bolt.
The theoretical strip out force only is not adequate to describe the joint strength. Unless you look at a eye bolt application for instance. But even there you have side loading to consider. On top of that is torque. Head friction and so forth...too much to mention. The image below highlights how nut design itself affects the load carrying capacity and how the load spreads over the first couple threads. In a) you can see that the first 4 threads carries 35%+25%+15%+10% = 85% of the max load. while in b) the load spreads to approx. 6 x 15% = 90% of max load. The that means that the threads in a) are loaded much higher (35/15=2.33) and therefore will yield differently than in case b). That's just to give an idea on the complexity of your question.
There are good books on threaded connections. Look up Introduction to the design and behavior of bolted joints by John Bickford.
Sample of 2D drill case axial loading FEA
Elmar
Unspecified Unspecified Mar 26, 2018 4:12 AM (in response to Evan Leftwick)Good day,
If you figure out the axial force on a bolt, then you can cross check from standart charts if the tension exceed the value you found. I dont like to `full scale` model the thread , stress singularities at vertices, edges etc.can mislead you.
- You can add bolt connection to simulation and run it,
-Check the foces acting on the bolt, you have shear and axial forcea-Axial force shouldnt exceed the tensile force of the material in the given diameter
b- Base plate and screwed plate must also withstand this stress, you can use charts you can find from web.
