Does anyone know why there isn't a gap between an object line and the datum symbol extension line when the datum symbol is moved away from the part? Is there any way to fix this?
This is controlled by Options, Document Properties, Annotations, Datums.
If you have the Base datums standard set to ISO
You get no gap.
If you have it set to ANSI
You do have a gap.
Hope this helps.
