I have to model a building in solidworks starting from the studs to the plywood making the walls. The problem I am having is trying to get the plywood fit the studs without having tons of in assembly cuts. Any advice on how to have minimal parts in the assembly and having the plywood fit the studs.
Without even seeing a sketch or maybe even a picture it is difficult to give you a good solution....
First thing I would say is you need to look at your design intent and in your case, space the studs for minimal cutting, however even in a house construction there are multiple cuts required.
