Joop Sleumer
From ECAD through Circuitwork to Solidworks
Discussion created by Joop Sleumer on Jan 16, 2009
Latest reply on Jan 29, 2009 by Joop Sleumer
I'm working at a company where we make powersupplies (www.pbfgroup.eu)
Our Electronic designers use a ECAD program called Eagle 4.16R2 (www.cadsoft.de). The mechenical designer (me) is using Solidworks.
Since a few months i'm trying to get export in IDF format from Eagle to Circuitworks. At this moment I can get the board imported in Circuitworks, componets are not reconized yet.
Now my questions:
- are there more of you using Eagle an Solidworks, if Yes does it work for you
- is it possible to connect the Electronical database to the Mechenical database
- is there more documantation or is there a tutorial for circuitworks. Till this moment I didn't found a course/education yet
- If you are using an other ECAD program but you are using circuitworks does it work fine for you or did you have to change/ program a lot.
I hope to start a discussion so there will be more and better use of Circuitworks
With regards,
Joop
SW2009 x64 SP1
Intel Core 2 Duo E8400 3GHz
8GB RAM
Nvidia FX1500
