Need help to create "SPLIT LINE" by a VBA macro
Question asked by Yehoshua Enuka on Sep 6, 2017
Latest reply on Sep 6, 2017 by Alex Burnett
I wrote a macro in VBA that creates a circle and then selects the circle. Afterwards the macro should project the circle on the surface (faces) and create a split line. My problem is that I cannot use selectbyID2 because I don't know in advance the coordinates of the faces that I need to select! So I thought of a workaround: to select all the faces. However, this doesn't work. When I run the following code the split line is not created. Please note that if I run the code and then just before the last line I click on 'Curves->create line' then the split line is created perfectly!!!
Please advise.
Thanks and best,
Yehoshua
boolstatus = Part.Extension.SelectByID2("Circle1@Rolled Circle", "SKETCH", 0, 0, 0, False, 4, Nothing, 0)
Dim swFace As SldWorks.Face
Dim swEnt As SldWorks.Entity
Dim bRet As Boolean
Dim swSelData As SldWorks.SelectData
Dim swBody As SldWorks.Body2
Dim vBodies As Variant
Set swSelMgr = Part.SelectionManager
Set swSelData = swSelMgr.CreateSelectData
vBodies = Part.GetBodies2(swAllBodies, True)
Set swPart = Part
Set swBody = vBodies(0)
Set swFace = swBody.GetFirstFace
Do While Not swFace Is Nothing
      Set swEnt = swFace
      ' Select using IEntity
      bRet = swEnt.Select4(True, swSelData)
      bRet = Part.Extension.SelectByID2("", "FACE", 0, 0, 0, True, 1, Nothing, 0)
      Set swFace = swFace.GetNextFace
  Loop
swPart.InsertSplitLineProject False, False
Any idea?
Thanks!
