David in the SolidWorks Task Scheduler there is a Print Task which allows you to control the Printer options and then set a batch of prints on their way. You can also explore #TASK which allows you to download an application and i am sure thee is a Print task i there which again will allow the printer settings to be controlled in advance of a batch process.
Ok i want printed on two printers. A4;A3 to one printer and A2;A1 on ploter . I think that i setting drwdot. On sheet format for A4 and A3 I set one printer and for A2;A1 set plotter.
