8 Replies Latest reply on Sep 5, 2017 5:11 PM by Nilesh Patel
    Select an Edge with SelectByID2
    Nadav Gover
      Is there anyway of using SelectByID2 to select an Edge?
      I need this in order to use InsertFillSurface2 (2013 SOLIDWORKS API Help - InsertFillSurface2 Method (IFeatureManager) ) which takes as an argument an array of Edges which must be selected with SelectByID2 as it states in the remarks.
      Or is there a way around it?
      Casting the Edge to an Entity an then use Select4 didn't do the work for me :/
        • Re: Select an Edge with SelectByID2
          Simon Turner
          When you used Entity.Select4, did you use a SelectData object to set the Mark?
              Nadav Gover
              Hi Simon,
              I currently have this (shortened, C#)
              SelectData swSelData = swSelMgr.CreateSelectData();
              swSelData.Mark = 257;
              Entity swEntity = (Entity)swEdge;
              status = swEntity.Select4(true, swSelData);
              And the Select4 returns false for some reason thus the status = false.
              Afterwards I try to call the InsertFillSurface2 method with swSelData as an argument for the boundries, obviously not working because the selection was unsuccessful.
              Any idea?
                  Nilesh Patel
                  Hi Nadav,
                  A specified in API help, edges MUST be selected using IModelDocExtension::SelectByID2 method. I don't think selecting edges using IEntity::Select4 method will work. Could you attach your part, so someone can have a look?
                  Regards,
                      Simon Turner
                      I think it should work with Select4, because the example it gives in the reference page for InsertFillSurface2 shows exactly that.
                      Look at "Get and Fill Gaps in Body Example (VBA)".
                        Nadav Gover
                        The part is Attached now.
                        I agree with what Simon said, also in my case I need to select more than 1 Edge for the boundary.
                        I thought of making a new sketch with converting the entities but this probably will take much longer.
                        As this is only a minor sub routine in my whole macro I would want to avoid time consuming procedures.
                        By the way, the only reason I want to do that (select edges) is to find which contour is the most outer contour, by filling all contours and than check which has the greatest area.
                        So if you guys have any other idea of how to achieve this, it will be great.
                            Simon Turner
                            This VBA code selects the outer loop of any selected face:
                            Dim Part As ModelDoc2
                                Dim selMgr As SelectionMgr
                                Dim selData As SelectData
                                Dim myFace As Face2
                                Dim myLoop As Loop2
                                Set Part = swApp.ActiveDoc
                                If Part Is Nothing Then Exit Sub
                                Set selMgr = Part.SelectionManager
                                If selMgr.GetSelectedObjectCount2(-1) <> 1 Then Exit Sub
                                If selMgr.GetSelectedObjectType3(1, -1) <> swSelFACES Then Exit Sub
                                Set selData = selMgr.CreateSelectData
                                Set myFace = selMgr.GetSelectedObject6(1, -1)
                                Set myLoop = myFace.GetFirstLoop
                                While Not myLoop Is Nothing
                                    If myLoop.IsOuter Then ProcessLoop myLoop
                                    Set myLoop = myLoop.GetNext
                                Wend
                            Sub ProcessLoop(myLoop As Loop2)
                                Dim myCoEdges As Variant
                                Dim myCoEdge As CoEdge
                                Dim myEdge As Edge
                                Dim myEnt As Entity
                                Dim i As Integer
                                myCoEdges = myLoop.GetCoEdges
                                If IsEmpty(myCoEdges) Then Exit Sub
                                Part.ClearSelection2 True
                                For i = 0 To UBound(myCoEdges)
                                    Set myCoEdge = myCoEdges(i)
                                    Set myEdge = myCoEdge.GetEdge
                                    Set myEnt = myEdge
                                    myEnt.Select4 True, Nothing
                                Next
                              Nilesh Patel
                              Hi Nadav,
                              I am still on SW2015 and can't open your part. But I will play with both options.
