5 Replies Latest reply on Sep 5, 2017 8:06 AM by Deepak Gupta
    Do something to cutlist 'FirstFeature' - VBA
    Raymond Yau
      I'm having some trouble getting the logic right on a macro I have. The macro currently performs a function to each and every item in the cutlist. Something like:
      Set swFeat = swModel.FirstFeature
      Do While Not swFeat is Nothing
      //set some variables
           If swFeat.GetTypeName = "CutListFolder" Then
                //Do something i.e. get cutlist properties
      set swFeat = swFeat.GetNextFeature
      loop
      But what if I wanted to perform an action only to the first item on the cutlist before the Do While loop? I tried to perform a function only to the first item on the list by adding the function outside the loop but for some reason, it doesn't get/select the first item on the list.
      If Not swFeat Is Nothing Then
      //Do something i.e add new property to first cutlist item
      //Debug.print new property
      //set other variables
                //Do something i.e. get all cutlist properties
      loop
      Sorry if its a bit vague, I'll update this with more info if it's not clear enough.
        • Re: Do something to cutlist 'FirstFeature' - VBA
          Nilesh Patel
          Hi Raymond,
          You will have to move following lines if you want to access the first item in the cut list folder
          1. //Do something i.e add new property to first cutlist item
          2. //Debug.print new property
          After this line:
          Remove following lines:
          1. If Not swFeat Is Nothing Then
          2. //Do something i.e add new property to first cutlist item
          3. //Debug.print new property
          4. End If
          The first feature in the part or assembly document is 'Favourites" or "History" folder.
          You will also have to make sure that when the 'Do While' loop is run second time, you skip codes for the first item in the cut list folder. Could you attach your part?
          Regards,
            Deepak Gupta
            Try these
            Option Explicit
            Dim swApp           As SldWorks.SldWorks
            Dim swModel         As ModelDoc2
            Dim swFeat          As SldWorks.Feature
            Dim strValue(1)     As String
            sub Main()
                Set swModel = swApp.ActiveDoc
                 Do While Not swFeat Is Nothing
                    If swFeat Is Nothing Then
                        Exit Do
                    If swFeat.GetTypeName2 = "CutListFolder" Then
                        swFeat.CustomPropertyManager.Get4 "DESCRIPTION", False, strValue(0), strValue(1)
                        Debug.Print strValue(1)
                        'Add you codes here
                        Exit Do
                    Set swFeat = swFeat.GetNextFeature
                Loop
            And please upload files to this forums directly. Check #18 of Forum Posting on how to attach files while replying to a post.
