Macro Sheet metal cut size
Question asked by Biko Te Winkel on Sep 4, 2017
Latest reply on Sep 19, 2017 by Biko Te Winkel
Hello guys,
On my Solidworks 2017 sp4 version i'm running a macro to automattically create/fill a cutlist with my own property names for sheet metal body's.
Now i've got a problem with this macro.
When i'm running this macro for a PART with multiple body's (sheet metal, weldments and extrudes) it's it's also changing the custom property's for my weldment files.
Is there anyone right here who can add an exeption to this macro? something like only change 'sheet metal' cutlist items?
The macro:
    Set swModel = swApp.ActiveDoc
    Set swModelDocExt = swModel.Extension
    ' Get the DeleteFace feature
    Set swFeat = swModel.FirstFeature
     Do While Not swFeat Is Nothing
        If swFeat Is Nothing Then
            Exit Do
        featureName = swFeat.Name
        If swFeat.GetTypeName2 = "CutListFolder" Then
             boolstatus = swModelDocExt.SelectByID2(featureName, "SUBWELDFOLDER", 0, 0, 0, False, 0, Nothing, 0)
            swModelDocExt.Create3DBoundingBox
            Set swCustPropMgr = swFeat.CustomPropertyManager
            swCustPropMgr.Add3 "Afmeting", swCustomInfoType_e.swCustomInfoText, """SW-3D-Bounding Box Width@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""" & " x """ & "SW-3D-Bounding Box Length@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""mm", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
            swCustPropMgr.Add3 "Benaming", swCustomInfoType_e.swCustomInfoText, "Plaat ""SW-Sheet Metal Thickness@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""mm", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
            swCustPropMgr.Add3 "Materiaal", swCustomInfoType_e.swCustomInfoText, """SW-Material@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
            swCustPropMgr.Add3 "Opmerking", swCustomInfoType_e.swCustomInfoText, """", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
        Debug.Print swFeat.GetTypeName2
        Set swFeat = swFeat.GetNextFeature
    Loop
    MsgBox "Done setting Afmeting, Benaming, Materiaal, Opmerking property"
Only a weldment works fine (no macro needed for the right custom propertys)
after adding a sheet metal body and running the macro, the custom propertys of the sheet metal are fine
but it also changed the weldment's custom properties by adding a bounding box.
I hope someone can help me changing this macro, i'm a leek with macro's!
Kind regards,
Biko
