I am making a 3D solid model of a iPhone. It was working out fine, but suddenly when I began sketching on a front plane, it was showing the sketches on the back of the model when I rotated it. I do not want that to happen. I don't want it to be transparent either since it's a part of the model. I was making a screen for the model. But when I rotated the model, the screen can still be seen. I attached a few pics to make it clear. How do I only make it view-able on that plane? Thank you.
Hi Kazi,
While you're editieditng the sketch I don't believe you can hide the sketch lines, Otherwise you'd be struggling to sketch accurately if the bodies were hiding all your entities!
If you exit the sketch then you wwill be able to hide the sketch lines.
