Re: Regarding Macro.
Deepak Gupta Sep 4, 2017 1:27 PM (in response to Saikiran Reddy)Are you able to finish recording OR not? Which version of SW you're using? Can you attach the recorded macro to check?
Saikiran Reddy Sep 5, 2017 4:30 AM (in response to Deepak Gupta)No, i am unable to start the record atleast. As soon as i start the record it is saying it saying sw has encourted the problem and it needs to close.
Deepak Gupta Sep 5, 2017 5:01 AM (in response to Saikiran Reddy)Then it could be related to Instability in SOLIDWORKS due to conflict with Microsoft KB3072630
Saikiran Reddy Sep 5, 2017 11:01 AM (in response to Deepak Gupta)Hello deepak, thanks for your reply, I tried according to link what you sent but still i am facing the same problem.
Deepak Gupta Sep 5, 2017 2:29 PM (in response to Saikiran Reddy)I would suggest you try a registry reset as explained here but make sure you take backups of the data first. Resetting the SOLIDWORKS registry
If that doesn't work, then reinstall SOLIDWORKS but first uninstall completely. Again make sure you take backups of the data first.
