Hi everyone, when i import a 2D dwg, often it happens(not always) that one visual line contains 3 or 4 enteties over each other. This makes the drawing 3 to 4 times as large and often impossible to scale. Is there a way to delete the doubles or simply unify?
Thanks in advance
Can you ask the source to not create duplicate lines.
It has been 10yrs or so since I last used AutoCAD, but I think there was a command "overkill" or "flatten" to remove duplicate lines.
