Doug Crow
Design Table Invalid Value
Discussion created by Doug Crow on Jan 16, 2009
I have a design table that worked with 2008 but does not function correctly with 2009. I am using a sweep/twist along a path defined by turns. This appears as an angle (one turn = 360) in the design table. In the 2008 version of this table I could have a value greater than 360. Attached is the part file of the spring with design table. Does anybody have a solution or have this same problem?
I have looked at some spring design macros and these are more complicated and larger than needed.
Thanks!
