Hi , despite I am new user of the Solidworks Forum here, I have been using Solidworks for about 2 years now, I have faced lots of problems but this one is completly turning me upside down.
Ok I find issues with the Solidworks Add-in Solidworks Electrical 3D, I want to modelize a drone (a quadcopter), with its frame, its motors, and all its different wires, and here come the problems. I have followed some tutorials on Youtube and Google in general just to touch a little bit with the Solidworks electrical interfaces and all..., and I have found a lot of "step by step" videos, showing how to actually create a SE schematic and linking it with the 3D assemblies ... But I find an issue when I want to route my cables. They simply don't route when I click the "route cables" option.
I explain more, I had created a project with a Schematic folio. The schematic contains two connectors with 3 circuit each and a 3D part with all its connections points. The problem is that when I link the 3 circuits of both connectors with simple wires the "route wire" option in Electrical 3D works perfectly (not perfectly I still have problems with routing paths and cable radius errors... but it still produces three smouth wires).
But once I integrate all those circuits in a single cable (a cable with 3 circuits) in the 2D schematic, the routing functions all fails to produce a route in the 3D electrical.
Thanks for helping me, this was my first question asked here in this forum, I hope I'll get an answer.
More information (a copy of the project) would be needed to really answer this question but based on your statement above I would check your cable diameter. If your wires are having trouble routing due to bend radius the sweep being created for the cable may be failing.
