RARay Ackley30/08/2017
I'm trying to make a tube connection between two parts that is a brazed copper tube. This means I'm not dragging and dropping "Tube Fittings" from the routing library as it attaches directly to the part.
Logically, I created connection points on both parts.  However, the UI is super non-intuitive and I'm hoping my frustrations here will help the Solidworks team incorporate some logical improvements in this regard.
Here are a few examples:
1) Clicking "Start at Point" then attempting to click the CPoint doesn't work.  It won't highlight/select the CPoint.
  - Remedy:  Click the CPoint first, so it is selected, THEN click "Start at Point".  This creates the start of the tube.
2) At that point, I start up Auto Route.  It says "Select a point to route from, and then a point, clip axis or line to route to."  So naturally I click the point to route from (the starting CPoint.  All is well so far.  Next step is "...and then a point, clip axis or line to route to."  So I try to select the destination CPoint on the 2nd part.  Won't select.  :-(
  - Remedy: I have to define a duplicate CPoint inside the tube assembly "part" (right on top of the destination part CPoint), via "Add Point".  Then I can select that CPoint.
  - Problem with remedy - if the destination part moves, the destination point/CPoint stays where it is.
