vb.net - Delete all appearance from a display state
Question asked by Richard Lessard on Aug 30, 2017
Latest reply on Sep 4, 2017 by Richard Lessard
I am trying to make a function that delete all appearances from a display state.  I have tryed many things and I am blocked at many places in the way.
From what I understand there are basically 2 possible ways to do it (see below code and explanations of everything I did for both ways).  If anybody has experience with those functions, a piece of working code or tips for me, it would be greatly appreciated because I am really stucked right now.  See also screenshots of one of the assemblies I am working with below.
First way : Using DeleteDisplayStateSpecificRenderMaterial
The first way is using the DeleteDisplayStateSpecificRenderMaterial function :
     ModelDocExtension.DeleteDisplayStateSpecificRenderMaterial( ByVal PWMaterialId1 As System.Object,  ByVal PWMaterialId2 As System.Object )
Using this way, I face 2 problems.
The first problem is to get the ids of the appearances (iRenderMaterial interface if I understand well).  When I use the following code, I get very inconsistent results accessing the RenderMaterial objects.  Meaning that I never get all the appearances contained in the assembly.  In assemblies that contains many appearances for many components, sometimes I can not access any rendermaterial object, sometimes I can access a few, but I never get them all.
          'ModelAsm is a valid ModelDoc2 object containing an assembly model
          Dim swModelDocExt As ModelDocExtension
          Dim displayStateNames(0) As String
          Dim renderMaterials As Object
          Dim nbRenderMaterials As Integer
          swModelDocExt = ModelAsm.Extension
          displayStateNames(0) = "Display State-1"
          'using GetRenderMaterialsCount2 gives inconsistent results, for any of the 3 syntaxes below.
          'In assemblies that contains many appearances, I sometimes get 0,
          'sometimes another number, but never the appearance count that I can see under the appearance tab in SolidWorks
          nbRenderMaterials = swModelDocExt.GetRenderMaterialsCount2(swDisplayStateOpts_e.swAllDisplayState, Nothing)
          nbRenderMaterials = swModelDocExt.GetRenderMaterialsCount2(swDisplayStateOpts_e.swSpecifyDisplayState, displayStateNames)
          nbRenderMaterials = swModelDocExt.GetRenderMaterialsCount2(swDisplayStateOpts_e.swThisDisplayState, Nothing)
          'here I can access the the number of rendermaterial that was returned using the corresponding GetRenderMaterialsCount2 syntax above
          renderMaterials = swModelDocExt.GetRenderMaterials2(swDisplayStateOpts_e.swAllDisplayState, Nothing)
          renderMaterials = swModelDocExt.GetRenderMaterials2(swDisplayStateOpts_e.swSpecifyDisplayState, displayStateNames)
          renderMaterials = swModelDocExt.GetRenderMaterials2(swDisplayStateOpts_e.swThisDisplayState, Nothing)
The second problem is using the DeleteDisplayStateSpecificRenderMaterial function.  The function returns true (as if it was a success), but It does not appear in the assembly, even after a rebuild or saving, closing and re-opening the file.  I tryed to use it in 2 ways.
First way (delete all render materials at once)
          Dim tbool As Boolean
          Dim iMat As RenderMaterial
          Dim iMatID1 As Integer
          Dim iMatID2 As Integer
          Dim MatsIDs1(0 To nbRenderMaterials - 1) As Integer
          Dim MatsIDs2(0 To nbRenderMaterials - 1) As Integer
          For i = 0 To nbRenderMaterials - 1
               iMat = renderMaterials(i)
               iMat.GetMaterialIds(iMatID1, iMatID2)
               MatsIDs1(i) = iMatID1
               MatsIDs2(i) = iMatID2
          Next
          tbool = swModelDocExt.DeleteDisplayStateSpecificRenderMaterial(MatsIDs1, MatsIDs2)
          'Here, tbool is true (as if it was a success), but the appearances are not deleted in SolidWorks
Second way, delete rendermaterials one by one
          Dim MatsIDs1(0) As Integer
          Dim MatsIDs2(0) As Integer
               MatsIDs1(0) = iMatID1
               MatsIDs2(0) = iMatID2
          Next
Second way : Looping trough components
Here the idea is to loop trough components and delete their applied appearances as answered by Alexandre Gragnano in this post : https://forum.solidworks.com/message/776101#comment-776101
Here is my adaptation in vb.net (and looping trough components).  I also tried the original  macro shown in the post, but without success (did not delete anything)
      Sub DeleteAllColors2(ModelAsm As ModelDoc2, Optional DisplayStateName As String = "")
           Dim vConfigName As Object = ModelAsm.GetConfigurationNames
           Dim swConfMgr As ConfigurationManager = ModelAsm.ConfigurationManager
           Dim swConf As Configuration = swConfMgr.ActiveConfiguration
           Dim swRootComp As Component2 = swConf.GetRootComponent3(True)
           Dim swModelDocExt As ModelDocExtension = ModelAsm.Extension
           'recursive search returns  all the component2 objects (all components and child components included in the assembly
           Dim FrameList As List(Of Component2) = recursiveSearch(swRootComp, AddressOf isTrue)
           For Each iFrame As Component2 In FrameList
                 'here, I tried both RemoveMaterialProperty2 and RemoveTextureByDisplayState functions.
                 'value returned by both functions is always false and nothing happen in SolidWorks
                 tbool = iFrame.RemoveMaterialProperty2(swInConfigurationOpts_e.swAllConfiguration, Nothing)
                 tbool = iFrame.RemoveTextureByDisplayState(DisplayStateName)
           Next
           ModelAsm.GraphicsRedraw2()
Screenshots of the assembly
