Hi all,
I am using 'Find Intersection' to select some points on a steel frame. Everything is working fine but I'm getting a series of lines that appear with the dimensions and are visible on the exported PDF sheets.
Any ideas of a setting or method to clear these?
Oli
Oli, i think this is a reported bug as below:
Here is a workaround. Set your Virtual Sharps to any of the others (I used "Star"). Create a Layer which is set to hidden and then add your Sharps to this- see below
