Hi! I have a little problem, I have a big assembly and some of my stuff is fixe but I dont have de choice to defixe my stuff.
The (F) in the tree , when I click right , I dont have any option to change that, where I go? Or why I have a F??
thankx
thankx
Here is what Grant was talking about.
If you have configurations you are able to decide which configurations it is fixed or floating in. Also as Grant said to have the assembly constrained you need to have at least one item fixed or mated to the origin. If you have a base part that supports or locates everything else that would be the part that usually should be fixed. I prefer to mate the 3 main planes of the main part to the 3 planes of the assembly.
You would need to have the subassembly active to be able to have the option to float a fixed part in the subassembly. If a part is not fixed or fully mated you can make the subassembly flexible and move the part. Here are the icons to make those changes.
