Clean property script
Question asked by Lasse Nielsen on Aug 29, 2017
Latest reply on Aug 29, 2017 by Michael Dekoning
Hello Forum,
I need some help with a macro. I have modified some code from another macro as seen below. I am trying to delete some old and very annoying properties from files located in the vault. Others need renaming due to confusing names. The idea is to run it as a task from the right-click menu.
So far the macro opens the file in question, but in read-only mode and thus not able to delete or rename any properties. I somehow need a chunk of code that checks the file out before starting the cleaning process.
Hopefully someone can help me out here?
Dim swModel As sldworks.ModelDoc2
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim Vault As Object
Dim boolProperty As Boolean
    docFileName = "<Filepath>"
    If LCase(Right(docFileName, 7)) = ".sldasm" Then
        swApp.Visible = True
        OpenAndSave docFileName
        Exit Sub
    Else
        Exit Sub
Sub OpenAndSave(docFileName)
    Dim swDocSpecification As SldWorks.DocumentSpecification
    'Login to vault
    Set Vault = CreateObject("ConisioLib.EdmVault.1")
    Vault.Login "Admin", "PW", "VaultName"
    'Open file with specifications
    Set swDocSpecification = swApp.GetOpenDocSpec(docFileName)
    swDocSpecification.Silent = True
    swDocSpecification.ConfigurationName = "Default"
    Set swModel = swApp.OpenDoc7(swDocSpecification)
    'CheckOut
    'What to do?
    'Test deleting property & test renaming property
    Set swCustPropMgr = swModel.Extension.CustomPropertyManager("Default")
    swCustPropMgr.Delete2 "Kunde"
    Dim strValue As String
    Dim strResolved As String
    boolProperty = swCustPropMgr.Get4("DimAfdeling", False, strValue, strResolved)
    If boolProperty = True Then
        swCustPropMgr.Delete2 "DimAfdeling"
        swCustPropMgr.Add3 "Department", swCustomInfoText, strValue, 1
    'CheckIn
    'What to do?
