53% through my installation, I get this message:
_________________________________________________________________
Error 27502. Could not connect to Microsoft SQL Server
'localhost\SQLEXPRESS'. [DBNETLIB][ConnectionOpen (Connect()).]
Specified SQL server not found. (6)
If the installation fails, contact Technical Support.
If you continue, you may encounter further errors. If you contact Technical Support, be prepared to provide the installation log files available in this directory <link>
__________________________________________________________________
THEN, this is the file data linked (attached). I have searched out every type of answer. If anyone knows how to reach an actual tech support agent. Please let me know!
**EDIT** Removed the file with info
To talk to someone in tech support, you would need to contact your VAR. They should provide any tech support you need.
