Abilash V.
To save SolidWorks Toolbox Components as Part Files Without Flag
Discussion created by Abilash V. on Aug 29, 2017
Latest reply on Aug 30, 2017 by Abilash V.
Procedure:
1.This helps to save the Toolbox components in Active Assembly to a location as per user input and to remove the Toolbox Flag.
2. Rebuild and save the Assembly for seeing the changes .
Dim swmodel As SldWorks.ModelDoc2
Dim swassem As SldWorks.AssemblyDoc
Dim vcomp As Variant
Dim swcomp As SldWorks.Component2
Dim swpart As SldWorks.ModelDoc2
Dim a As Integer
Dim bool As Boolean
Dim err As Long
Dim war As Long
Dim asname As String
Dim pname As String
Dim floc As String
Set swmodel = swApp.ActiveDoc
Set swassem = swmodel
floc = InputBox("enter the location")
asname = swmodel.GetTitle
vcomp = swassem.GetComponents(True)
For i = 0 To UBound(vcomp)
Set swcomp = vcomp(i)
Set swpart = swcomp.GetModelDoc2
If swpart Is Nothing Then
Else
'MsgBox swpart.GetTitle
pname = swpart.GetTitle
a = swpart.Extension.ToolboxPartType
If a = 1 Then
'MsgBox ("toolbox component")
swApp.ActivateDoc3 pname, False, 1, err
bool = swpart.Extension.SaveAs(floc & "\" & swpart.GetTitle & i & ".sldprt", 0, 1, Nothing, err, war)
swpart.Extension.ToolboxPartType = 0
'MsgBox (swpart.Extension.ToolboxPartType)
bool = swpart.Save3(1, err, war)
'MsgBox bool
swApp.ActivateDoc3 asname, True, 1, err
ElseIf a = 2 Then
'MsgBox bool
Next
swmodel.ForceRebuild3 False
bool = swmodel.Save3(1, err, war)
Regards
Abilash
