Can't figure out what's going on. When I try to save as another file type, it acts like it's processing but then there's no file to be found.
Running SW 2015 in Parallels
is it a part or an assembly....are you saving just outside surfaces or the whole thing?
check the options tab on the save as window..
Sally Diener wrote:
SW 2015 doesn't have export in the options menu, where else would it be?
To get to import options:
To get to export option:
Do the exact same thing, except with "save as.." instead of "open".
my guess is the DLL for the translator is hosed....suggest you shut everything down... reboot...(parallels could also be hosed?)
Sally,.. I'm suggesting something has gone wrong with the STEP translator DLL.. it could not be registered, the registry is messed up.. so, if you reboot, it may register/run?
If the registry is hose.. you may need to reset it,.. very easy to do.. search for resetting registry or this link..
Resetting the SOLIDWORKS registry
As for Parallels,.. it's a virtual system so.. if you have not already,.. it may need to reboot as well?
