In SW 2014 it was very straightforward to save an assembly as a .STEP model. However now that our company switched to SW 2017 I get prompted to save referenced documents after the initial assembly has been saved. If the assembly is large I sometimes have to click away 20-30 times in order to get rid of the prompts. What has changed from 2014 version that causes this. Has anyone had the same issue and found a solution?
Jyrki, just a shot in the dark here ... Hope it helps
