Good morning everybody and good day.
I have done some rendering with SW Visualize 2017 STANDARD in JPG but I can not get better result than this image.
It is rendered 1600 pix wide, 96 DPI, 5000 passes. ( yes 5000, anything less is horrible render. )
To me, the sharpness is really really poor. It looks OK but the edges and details are not sharp at all.
Any suggestion guys? I think I am really missing something out.
I have pretty good PC setup so no issue should be found here.( Win 10, i7-7700K, 4.2 GHz, QUADRO M4000 G Card, )
Thank you
While I'm not a Visualize user I can give you a few suggestions ... Real objects never have infinitely sharp edges, there will always be a small highlight on an edge. Unless there is actually a small radius/fillet or chamfer on an edge in the model, the renderer must add that in. Its possible the Visualize renderer has the ability to do this, check the rendering settings.
The second consideration is the light to dark range, or levels. Sometimes there is a rendering setting called "Gamma" which can help. Otherwise is possible to process after in Photoshop or similar as shown.
