RPRicardo Peixoto23/08/2017
Hello, I have this simple model, that apparently has no problems with it, but when I try to use sketch_20 to cut the body, I kept get the message that "Feature failed to cut the body".
When I make the sketch intersect the other body, the feature works...even if I select the correct body to be cut with the feature scope, the feature doesn't work in the body that I want.
Could this be a software issue?!
