I have two 3D sketches of a tubular chassis of either side of the vehicle. Both sketches have 3 of the same intersecting lines. I did it this way because of measuring limitations and planned to just merge the two in Solidworks. I'm having issues aligning the two sketches based on the shared geometry. Any suggestions?
What about adding a new "alignment" sketch above your 3D sketches.Add lines that will be used to align the 3D sketches. Then you can delete the 3 intersecting lines from the 3D sketches.
