Macro Help
Question asked by Eric Eric on Aug 20, 2017
Latest reply on Aug 21, 2017 by Deepak Gupta
I was wondering if someone would have a good article or could point me in the right direction to learn how to write effective macro's.
I recently purchased a G13 gaming keypad and would love to have all of my "common tasks" assigned to a macro that would be activated by the hotkey on the keypad. That potion of it i am not concerned with, its the actual writing of the macros.
I would like to have macros
  1. Many times i have a part title that is to long and overflows the title block so i have to go in and edit the sheet format and make the font smaller; 14pt to 10pt.
  2. Insert a pre-made note style from the design library
  3. I have a macro that will add properties IF they do not exist already, it works just fine but i am curious how i can add the weight and material already assigned/calculated. (see picture)
here is what i have for a macro for line item 3;
Option Explicit
Public Enum swDocumentTypes_e
    swDocNONE = 0
    swDocPART = 1
    swDocASSEMBLY = 2
End Enum
    Dim swApp As Object
    Dim Part As Object
    Dim tDate As Date
    Set Part = swApp.ActiveDoc  ' Get currently active document
    Select Case Part.GetType
        Case swDocPART ' If active file is a part then insert PART custom properties
             Part.AddCustomInfo "PartNo", "Text", "****" ' Part Number
             Part.AddCustomInfo "Title", "Text", "****" ' Title
             Part.AddCustomInfo "Description", "Text", "****" ' Description
             Part.AddCustomInfo "Revision", "Text", "1" ' Revision
             Part.AddCustomInfo "DrawnBy", "Text", "EAW" ' Drawn By
           ' Part.AddCustomInfo "DrawnDate", "Text", tDate ' Drawn Date
             Part.AddCustomInfo "EngineeringApproval", "Text", "MAW" ' Engineering Approval
             Part.AddCustomInfo "Finish", "Text", "BLACK ANODIZE" ' Finish
             Part.AddCustomInfo "Material", "Text", "---" ' Material
             Part.AddCustomInfo "Weight", "Text", "---" ' Weight
             Part.AddCustomInfo "Vendor", "Text", "**" ' Vendor
             Part.AddCustomInfo "VendorNo", "Text", "N/A" ' Vendor P/N
             Part.AddCustomInfo "Manufacturer", "Text", "N/A" ' Manufacturer
             Part.AddCustomInfo "Manufacturer PN", "Text", "N/A" ' Manufacturer P/N
             Part.DeleteCustomInfo "Desc1"   'Removes existing property from downloaded McMaster Carr part
             Part.DeleteCustomInfo "Desc2"   'Removes existing property from downloaded McMaster Carr part
             Part.DeleteCustomInfo "Desc3"   'Removes existing property from downloaded McMaster Carr part
        Case swDocASSEMBLY ' If active file is an assembly then insert ASSEMBLY custom properties
             Part.AddCustomInfo "PartNo", "Text", "SEE BOM" ' Part Number
             Part.AddCustomInfo "Finish", "Text", "SEE BOM" ' Finish
             Part.AddCustomInfo "Material", "Text", "SEE BOM" ' Material
