Can anyone tell me what is causing the following; when;
#1. When I view a dwg in paper space the area in the view port seems to have some sort of additional view port (without visible border) that prevents me seeing the entire dwg if I have the dwg zoomed out. As I zoom in (enlarge the dwg) this view port grows until I zoom close enough that the title block is no longer visable. At that point, I can see the entire view port and dwg with in. It is almost like there is a second viewport within that is located in the lower right-hand corner of the paper. This only happens on one of my computers so I am guessing it is just a setting.
#2. When open a dwg in the same computer that was opened in a different computer I have to run "error check" before I can select any part of the dwg.
Any help is appreciated.
Doug
